Ga door naar hoofdinhoud
Canon EOS Rebel T5 Back Panel Removal
Wat je nodig hebt
  1. Canon EOS Rebel T5 Back Panel Removal, Battery: stap 1, afbeelding 1 van 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Back Panel Removal: stap 2, afbeelding 1 van 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Back Panel Removal, Back Panel: stap 3, afbeelding 1 van 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Back Panel Removal: stap 4, afbeelding 1 van 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Back Panel Removal: stap 5, afbeelding 1 van 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  6. Canon EOS Rebel T5 Back Panel Removal: stap 6, afbeelding 1 van 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  7. Canon EOS Rebel T5 Back Panel Removal: stap 7, afbeelding 1 van 3 Canon EOS Rebel T5 Back Panel Removal: stap 7, afbeelding 2 van 3 Canon EOS Rebel T5 Back Panel Removal: stap 7, afbeelding 3 van 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Johnyp
254 Reputatie
1 Handleiding geschreven
USF Tampa, Team 16-4, Wollert Fall 2015 Lid van USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 23
Altijd: 3,374
