Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the battery cover at the bottom of the camera.
Pull down on the black tab to open the cover.
Push the grey tab on the right side of the battery.
Remove the battery from the slot.
Use the spudger to pry off the rubber grip and reveal the screws.
Unscrew the four 5.5mm Torx screws using the Torx T6 screwdriver.
Pull off the plastic cover from the viewfinder.
Unscrew the two 3.4mm Phillips screws using the Phillips #00 screwdriver.
Remove the following screws from the device using the Phillips #00 screwdriver:
Two 3.4mm Phillips head screws.
Two 5.9mm Phillips head screw.
One 3.4mm Phillips head screw.
One 5.9 mm Phillips head screw.
In the lower right corner of the mother board, detach the blue cable.
Then detach the ribbon cable going from the motherboard to the rear panel.
In the upper left corner of the motherboard, remove the small multicolored wire from the motherboard.
Use the plastic opening tool to flip up ribbon cable connector.
Gently disconnect the ribbon cable by pulling it away from the motherboard.
In the upper right corner of the motherboard, use the plastic opening tool to remove the clear cable connector from the motherboard.
Use the plastic opening tool to remove the ribbon cable connecting the image sensor to the motherboard.
Use the plastic opening tool to push on the indents of the plastic header to disconnect from the motherboard.
Make sure all cables are disconnected from the motherboard.
Remove the following screws from the motherboard using the Phillips #00 screwdriver:
Two 3.9mm Phillips head screws.
Three 2.9mm Phillips head screws
Gently pull the motherboard out of the camera.
16 andere personen hebben deze handleiding voltooid.
2 opmerkingen
This guide gets an upvote.
It's the first camera disassembly guide I've seen so far on ifixit that includes the single most important precaution: the camera has a body cap fitted to avoid dust, dirt or other objects getting into the mirror box. Bravo!
