Ga door naar hoofdinhoud
Canon EOS Rebel T4i Battery Replacement
  1. Canon EOS Rebel T4i Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Battery Replacement: stap 2, afbeelding 1 van 1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nimisha Patel
164 Reputatie
1 Handleiding geschreven
Cal Poly, Team 12-33, Maness Spring 2014 Lid van Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 Leden
14 handleidingen geschreven
Één opmerking
Black tab on cover of the battery is constantly disengaging either when I am using or in my camera bag therefore battery runs down. Seems like a design fault to me. Anyone else having this problem ? Have been using sticky tape to keep it in place but still have a problem with the cover moving around and disengaging battery. Replacing with a new flimsy one from Canon at minimum cost of £40 is not on - knowing it will only happen again. I have given author 30 points for covering the topic but sadly have no idea how to solve this problem
esther allwood - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 36
Altijd: 3,077
