Inleiding
Replacing the motherboard is a last resort for correcting water damage to the camera. This guide will help you remove it step-by-step.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Peel away the rubber grip on the left side of the camera with your fingers.
18 andere personen hebben deze handleiding voltooid.
6 Opmerkingen
There was one huge step left out. On the T3i there is a fiber optic cable connection on the underside, top right hand side of the motherboard. If you don't reconnect this before reassembly your camera won't work. It is difficult to make sure both this cable and the adjacent white round-wire cable are connected before putting the motherboard back in place.
I concur with Albert Einstein. It was very difficult. This should be mentioned int the steps, not reserved for the comments!
Yes, 15 step. to make it easier to connect the optical cable and the second rear cable is better to remove the top cover
I want to know a camera repair shop where I can send my Canon Rebel T3i.
