Ga door naar hoofdinhoud
Canon EOS Rebel T2i Tripod Mount Replacement
Wat je nodig hebt
  1. Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: stap 1, afbeelding 1 van 2 Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: stap 1, afbeelding 2 van 2
    • Turn off camera using the power button on the top of the camera.
    • On the bottom of the camera, open the battery door and remove the battery.
  2. Canon EOS Rebel T2i Tripod Mount Replacement: stap 2, afbeelding 1 van 1
    • Remove the 7 screws from the bottom of the camera using a Phillips screwdriver
  3. Canon EOS Rebel T2i Tripod Mount Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws on the right side of the camera.
  4. Canon EOS Rebel T2i Tripod Mount Replacement: stap 4, afbeelding 1 van 1
    • Remove 1 screw from the left side of the camera.
    • Inside the rubber door, remove the two silver screws.
  5. Canon EOS Rebel T2i Tripod Mount Replacement: stap 5, afbeelding 1 van 1
    • Remove the two black screws on the front of the camera just above the lens mounting ring.
    • NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
  6. Canon EOS Rebel T2i Tripod Mount Replacement: stap 6, afbeelding 1 van 2 Canon EOS Rebel T2i Tripod Mount Replacement: stap 6, afbeelding 2 van 2
    • Using the spudger and plastic opening tool, pry the back of the camera loose.
  7. Canon EOS Rebel T2i Tripod Mount Replacement: stap 7, afbeelding 1 van 1
    • Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
  8. Canon EOS Rebel T2i Tripod Mount Replacement: stap 8, afbeelding 1 van 2 Canon EOS Rebel T2i Tripod Mount Replacement: stap 8, afbeelding 2 van 2
    • The screws holding the tripod mount are now exposed.
    • Remove the screws securing the tripod mount
    • With the screws removed, the tripod mount can now be easily pulled free.
Conclusie
Jacob Jaskolka
745 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-1, Shastany Spring 2015 Lid van UMass Dartmouth, Team 1-1, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 1,664
