Ga door naar hoofdinhoud
Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement
Wat je nodig hebt
  1. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement, Dioptric Adjustment Lens: stap 1, afbeelding 1 van 2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement, Dioptric Adjustment Lens: stap 1, afbeelding 2 van 2
    • Turn off camera using the power button on the top of the camera.
    • On the bottom of the camera, open the battery door and remove the battery.
  2. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 2, afbeelding 1 van 1
    • Remove the 7 screws from the bottom of the camera using a Phillips screwdriver
  3. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 3, afbeelding 1 van 1
    • On the top cover, remove the two screws from under the metal tabs that are used to attach the camera straps.
  4. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 4, afbeelding 1 van 1
    • Remove the two screws on the right side of the camera.
  5. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 5, afbeelding 1 van 1
    • Remove 1 screw from the left side of the camera.
    • Inside the rubber door, remove the two black screws.
  6. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 6, afbeelding 1 van 1
    • Remove the two screws beneath the eyepiece
  7. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 7, afbeelding 1 van 1
    • Remove the screw in the center of the viewfinder focus knob located to the right of the eyepiece.
  8. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 8, afbeelding 1 van 1
    • Remove the two black screws on the front of the camera just above the lens mounting ring.
    • NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
  9. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 9, afbeelding 1 van 3 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 9, afbeelding 2 van 3 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 9, afbeelding 3 van 3
    • Using the spudger and plastic opening tool, pry the back of the camera loose.
    • Remove the ribbon connector on the lower left hand side of the circuit board.
  10. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 10, afbeelding 1 van 1
    • Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
  11. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 11, afbeelding 1 van 1
    • Remove the ribbon connector on the upper right hand side of the circuit board.
    • Remove the microphone connection on the upper left hand side of the circuit board.
  12. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 12, afbeelding 1 van 1
    • On the lower left side on the front of the camera, disconnect the red and yellow wires from the circuit board.
  13. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 13, afbeelding 1 van 1
    • Pull the top cover free.
  14. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 14, afbeelding 1 van 2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 14, afbeelding 2 van 2
    • Remove the red wire that travels across the mirror box.
  15. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 15, afbeelding 1 van 1
    • Remove the 4 screws holding the mirror box in place.
  16. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 16, afbeelding 1 van 2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 16, afbeelding 2 van 2
    • Remove 3 screws to disconnect the ribbon mount assembly
  17. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 17, afbeelding 1 van 2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 17, afbeelding 2 van 2
    • Now that the top assembly is free, this exposes another screw on the right side of the mirror box.
    • Remove this screw.
    • Remove the orange ribbon cable.
  18. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 18, afbeelding 1 van 1
    • Remove the viewfinder assembly from the camera.The screws that hold the eyepiece in place are accessible. Remove these 3 screws from the rear face of the eyepiece. Two screws are located at the bottom and one screw is located on top.
  19. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 19, afbeelding 1 van 2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 19, afbeelding 2 van 2
    • With the screws removed, the eyepiece can easily be pulled free.
  20. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 20, afbeelding 1 van 1
    • Swivel the dioptric lens 90 degrees.
  21. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 21, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
  22. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: stap 22, afbeelding 1 van 1
    • Compress spring and remove spring and dioptric lens assembly
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jacob Jaskolka
745 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-1, Shastany Spring 2015 Lid van UMass Dartmouth, Team 1-1, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G1
3 Leden
Één opmerking
Thank u for the clear directives.
Really helped
For those who are intending to clean the internal prism mirrors, do note the two pieces on the top are no made of glass hence easily scratched. Best to avold wiping them.
Lex - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 3,558
