Ga door naar hoofdinhoud
Canon EOS Rebel T2i Clock Battery Replacement
Wat je nodig hebt
  1. Canon EOS Rebel T2i Clock Battery Replacement, Clock Battery: stap 1, afbeelding 1 van 2 Canon EOS Rebel T2i Clock Battery Replacement, Clock Battery: stap 1, afbeelding 2 van 2
    • This is not reversible and your camera will look like this forever after snapping off the plastic clip.
    • Unfortunately I don't have a before picture, but the battery is under a plastic cover that you have to snap off.
    • I did not take the 2nd picture, but it is an example of what it looks like here before breaking the plastic. Source:
    • Replacing internal backup battery of Canon EOS Rebel T3i camera
  2. Canon EOS Rebel T2i Clock Battery Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Can use thin flat-head screwdriver or tweezers to pry off the cover and reveal the battery slot.
  3. Canon EOS Rebel T2i Clock Battery Replacement: stap 3, afbeelding 1 van 2 Canon EOS Rebel T2i Clock Battery Replacement: stap 3, afbeelding 2 van 2
    • Can now see the battery and any model numbers on it. On my camera it is labeled "MS614SE"
    • Use a thin flat-head screwdriver or your tweezers to get the old battery out.
    • Slide in the new one and push it in with your finger.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Alejandro Marino
154 Reputatie
1 Handleiding geschreven
Één opmerking
Hi, Great help!
Where can I buy the replacement MS614SE?
Kam
Kam Lam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 81
Altijd: 2,488
