Ga door naar hoofdinhoud
Canon EOS Rebel G Viewfinder Replacement
Wat je nodig hebt
    1. Canon EOS Rebel G Viewfinder Replacement, Front Panel: stap 1, afbeelding 1 van 1
      • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel G Viewfinder Replacement: stap 2, afbeelding 1 van 2 Canon EOS Rebel G Viewfinder Replacement: stap 2, afbeelding 2 van 2
      • Using your finger, peel back the textured grip so the components are separated.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel G Viewfinder Replacement: stap 3, afbeelding 1 van 3 Canon EOS Rebel G Viewfinder Replacement: stap 3, afbeelding 2 van 3 Canon EOS Rebel G Viewfinder Replacement: stap 3, afbeelding 3 van 3
      • Using the flat end of a spudger, loosen the connection between the front panel and the device.
      • Remove the front panel using your hands.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS Rebel G Viewfinder Replacement, Top Panel: stap 4, afbeelding 1 van 1
      • Turn Camera over.
      • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel G Viewfinder Replacement: stap 5, afbeelding 1 van 1
      • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel G Viewfinder Replacement: stap 6, afbeelding 1 van 1
      • Lay the camera on its back.
      • Unsolder the flash connection from the motherboard as noted by the blue circle.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS Rebel G Viewfinder Replacement: stap 7, afbeelding 1 van 3 Canon EOS Rebel G Viewfinder Replacement: stap 7, afbeelding 2 van 3 Canon EOS Rebel G Viewfinder Replacement: stap 7, afbeelding 3 van 3
      • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS Rebel G Viewfinder Replacement, Viewfinder: stap 8, afbeelding 1 van 1
      • Unscrew the screws on either side of the viewfinder until the viewfinder can be lifted off
      • Two 8.5 mm Phillips screws
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kyle Reis
52 Reputatie
4 handleidingen geschreven
Cal Poly, Team 14-9, Forte Spring 2012 Lid van Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Leden
144 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 76
Altijd: 3,684
