Inleiding
This guide shows you how to install the anchors for the camera strap.
Wat je nodig hebt
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Turn Camera over.
Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Unscrew the 6.8 Phillips screw that holds the strap anchor by the LCD.
Conclusie
