Ga door naar hoofdinhoud
Canon EOS Rebel G Back Panel Replacement
Wat je nodig hebt
    1. Canon EOS Rebel G Back Panel Replacement, Front Panel: stap 1, afbeelding 1 van 1
      • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel G Back Panel Replacement: stap 2, afbeelding 1 van 2 Canon EOS Rebel G Back Panel Replacement: stap 2, afbeelding 2 van 2
      • Using your finger, peel back the textured grip so the components are separated.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel G Back Panel Replacement: stap 3, afbeelding 1 van 3 Canon EOS Rebel G Back Panel Replacement: stap 3, afbeelding 2 van 3 Canon EOS Rebel G Back Panel Replacement: stap 3, afbeelding 3 van 3
      • Using the flat end of a spudger, loosen the connection between the front panel and the device.
      • Remove the front panel using your hands.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS Rebel G Back Panel Replacement, Top Panel: stap 4, afbeelding 1 van 1
      • Turn Camera over.
      • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel G Back Panel Replacement: stap 5, afbeelding 1 van 1
      • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel G Back Panel Replacement: stap 6, afbeelding 1 van 1
      • Lay the camera on its back.
      • Unsolder the flash connection from the motherboard as noted by the blue circle.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS Rebel G Back Panel Replacement: stap 7, afbeelding 1 van 3 Canon EOS Rebel G Back Panel Replacement: stap 7, afbeelding 2 van 3 Canon EOS Rebel G Back Panel Replacement: stap 7, afbeelding 3 van 3
      • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS Rebel G Back Panel Replacement, Back Panel: stap 8, afbeelding 1 van 1
      • Using a #00 Philllips screw driver, unscrew the 6.8 mm Phillips screw that holds the strap anchor noted by the red circle.
      • Remove the strap anchor.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel G Back Panel Replacement: stap 9, afbeelding 1 van 1
      • Unlatch the back panel.
      • Using a #00 Phillips screw driver, unscrew the six screws on the bottom of the camera.
      • One 7.4 mm Phillips screw
      • Two 6.0 mm Phillips screws
      • Two 4.4 mm Phillips screws
      • One 3.9 mm Phillips screw
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel G Back Panel Replacement: stap 10, afbeelding 1 van 3 Canon EOS Rebel G Back Panel Replacement: stap 10, afbeelding 2 van 3 Canon EOS Rebel G Back Panel Replacement: stap 10, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • From the bottom of the camera push the hinge rod in with your finger.
      • Return the camera to its upright position.
      • Use pliers (or tweezers) to pull the rod out from the top.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Zach
46 Reputatie
8 handleidingen geschreven
Cal Poly, Team 14-9, Forte Spring 2012 Lid van Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Leden
144 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 53
Altijd: 2,507
