Ga door naar hoofdinhoud
Canon EOS Digital Rebel (300D) Front Casing Replacement
Wat je nodig hebt
  1. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the front screws: stap 1, afbeelding 1 van 1
    • Remove the two 7mm philips screws from the front casing.
  2. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove bottom screws: stap 2, afbeelding 1 van 1
    • Remove the three 1/8" philips screws from the bottom.
    • Remove the single 3/16" philips screw from the bottom.
  3. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the right side screws: stap 3, afbeelding 1 van 1
    • Remove the two 1/8" philip screws from the right side of the front casing.
  4. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: stap 4, afbeelding 1 van 2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: stap 4, afbeelding 2 van 2
    • Locate the lock of the battery door and pull it for allowing the door to be removed.
    • Remove the battery door.
  5. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the battery door hinge mount: stap 5, afbeelding 1 van 1
    • Remove the two 1/8" philips screws from the hinge mount.
    • Take out the door hinge mount.
  6. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: stap 6, afbeelding 1 van 2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: stap 6, afbeelding 2 van 2
    • Remove the screw holding the black cap which covers access holes to the screws holding the front casing to the battery compartment.
    • Remove the black cap pulling it to the right.
    • Remove the two 3/16" philips screws.
Conclusie
Claudio Felix
863 Reputatie
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 19
Altijd: 1,076
