Ga door naar hoofdinhoud
Canon EOS 60D Rear Cover Removal
Wat je nodig hebt
  1. Canon EOS 60D Rear Cover Removal, Rear LCD Screen Dissasembly: stap 1, afbeelding 1 van 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear Cover Removal: stap 2, afbeelding 1 van 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear Cover Removal: stap 3, afbeelding 1 van 2 Canon EOS 60D Rear Cover Removal: stap 3, afbeelding 2 van 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear Cover Removal: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear Cover Removal, Removing Rear Cover: stap 5, afbeelding 1 van 2 Canon EOS 60D Rear Cover Removal, Removing Rear Cover: stap 5, afbeelding 2 van 2
    • Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
    • Turn the swivel around to expose the remaining of the aforementioned screws.
    • Then use the PH00 screw driver to remove them.
  6. Canon EOS 60D Rear Cover Removal: stap 6, afbeelding 1 van 2 Canon EOS 60D Rear Cover Removal: stap 6, afbeelding 2 van 2
    • The eye piece will slide right off with a firm push upwards.
    • Remove the 3.4 mm Phillips #PH00 screw using a PH00 screw driver.
    • Remove the two 9.9 mm Phillips #PH00 screws using the PH00 screwdriver.
  7. Canon EOS 60D Rear Cover Removal: stap 7, afbeelding 1 van 1
    • Using the PH00 screwdriver, remove the 3.8 mm Phillips #PH00 screw located on the back of the camera.
  8. Canon EOS 60D Rear Cover Removal: stap 8, afbeelding 1 van 2 Canon EOS 60D Rear Cover Removal: stap 8, afbeelding 2 van 2
    • Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
    • Remove the four different sized screws located beneath the rubber grip.
    • 6 mm Phillips #PH00 screw.
    • 3.4 mm Phillips #PH00 screw.
    • 3.9 mm Phillips #PH00 screw.
    • 2.2 mm Phillips #PH00 screw.
  9. Canon EOS 60D Rear Cover Removal: stap 9, afbeelding 1 van 2 Canon EOS 60D Rear Cover Removal: stap 9, afbeelding 2 van 2
    • Using the plastic opening tool, carefully pry off the the side cover.
  10. Canon EOS 60D Rear Cover Removal: stap 10, afbeelding 1 van 1
    • Remove two 4.8 mm Phillips #PH00 screws from the memory card side of camera using the PH00 screwdriver.
  11. Canon EOS 60D Rear Cover Removal: stap 11, afbeelding 1 van 1
    • Look at the bottom of the camera so the serial number tag reads up right.
    • Using the PH00 screw driver, remove the top three 3.5 mm Phillips #PH00 screws.
  12. Canon EOS 60D Rear Cover Removal: stap 12, afbeelding 1 van 1
    • Now gently pull the back cover off the camera.
    • Gently pull the orange wire connected to the motherboard of the camera up and off of the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler Vaal
695 Reputatie
3 handleidingen geschreven
USF Tampa, Team 16-6, Wollert Fall 2015 Lid van USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 31
Altijd: 2,526
