Ga door naar hoofdinhoud
Canon EOS 40D Date and Time Battery Replacement
Wat je nodig hebt
  1. Canon EOS 40D Date and Time Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Date and Time Battery Replacement: stap 2, afbeelding 1 van 1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Date and Time Battery Replacement: stap 3, afbeelding 1 van 1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: stap 4, afbeelding 1 van 3 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: stap 4, afbeelding 2 van 3 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: stap 4, afbeelding 3 van 3
    • Remove the date and time battery holder by sliding it out of the slot.
  5. Canon EOS 40D Date and Time Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the date and time battery from the battery holder.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Doug Kruse
788 Reputatie
3 handleidingen geschreven
USF Tampa, Team 12-3, Blackwell Fall 2015 Lid van USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Leden
16 handleidingen geschreven
6Gids Commentaar
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
David Drinkwater - Antwoord
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
Stephen Spratley - Antwoord
This was so helpful, thank you! Also if you are in a jam and do not have a CR2016, you can use a CR2032 directly without using the normal battery tray.
paniak - Antwoord
Great help! Accurate, easy to follow directions
Jack Applegate - Antwoord
Excellent. Just what I needed, to bring life back to the dead.
pvlewisnz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 134
Altijd: 16,912
