Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the batteries from the camera by sliding them out into your palm.
Remove the two black 4.5mm screws above and below the latch.
Using your finger, carefully pry open the side panel from the top of camera.
Pull panel downwards to remove.
Flip camera over to the bottom.
Remove the one 5mm Phillips #1 silver screw.
Remove the front panel by pulling away from the side with the lever.
Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
Remove five black 4.8mm Phillips #1 screws.
Simply remove the bottom panel by prying it off with your finger.
Be wary of a loose piece of foam attached to the bottom panel.
Remove two black 4.8mm Phillips #1 screws on the front of the camera.
