Ga door naar hoofdinhoud
Canon EOS 300 Side Panel with Grip Replacement
Wat je nodig hebt
  1. Canon EOS 300 Side Panel with Grip Replacement, Batteries: stap 1, afbeelding 1 van 3 Canon EOS 300 Side Panel with Grip Replacement, Batteries: stap 1, afbeelding 2 van 3 Canon EOS 300 Side Panel with Grip Replacement, Batteries: stap 1, afbeelding 3 van 3
    • Open up the battery door.
  2. Canon EOS 300 Side Panel with Grip Replacement: stap 2, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement: stap 2, afbeelding 2 van 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: stap 3, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: stap 3, afbeelding 2 van 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Side Panel with Grip Replacement: stap 4, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement: stap 4, afbeelding 2 van 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Side Panel with Grip Replacement: stap 5, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement: stap 5, afbeelding 2 van 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Side Panel with Grip Replacement, Front Panel: stap 6, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement, Front Panel: stap 6, afbeelding 2 van 2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Side Panel with Grip Replacement: stap 7, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement: stap 7, afbeelding 2 van 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Side Panel with Grip Replacement: stap 8, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement: stap 8, afbeelding 2 van 2
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: stap 9, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: stap 9, afbeelding 2 van 2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Side Panel with Grip Replacement: stap 10, afbeelding 1 van 3 Canon EOS 300 Side Panel with Grip Replacement: stap 10, afbeelding 2 van 3 Canon EOS 300 Side Panel with Grip Replacement: stap 10, afbeelding 3 van 3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: stap 11, afbeelding 1 van 3 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: stap 11, afbeelding 2 van 3 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: stap 11, afbeelding 3 van 3
    • Remove the remote control socket cover.
  12. Canon EOS 300 Side Panel with Grip Replacement: stap 12, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement: stap 12, afbeelding 2 van 2
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Side Panel with Grip Replacement: stap 13, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement: stap 13, afbeelding 2 van 2
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Side Panel with Grip Replacement: stap 14, afbeelding 1 van 2 Canon EOS 300 Side Panel with Grip Replacement: stap 14, afbeelding 2 van 2
    • Pry open the side grip using a spudger.
Conclusie
Jordan Tang
590 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-20, Maness Winter 2014 Lid van Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Leden
32 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 884
