Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the 4.8 mm black screw on the left side of the camera.
Remove the front panel by lifting it away from the camera's body.
Remove the two 4.75 mm black screws located on the top of the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Slowly separate the top panel from the camera by pushing it upward.
Remove the two 9.5 mm black screws that attach the inner eyepiece to the camera's body and remove the eyepiece.
Remove the two 4.3 mm silver screws on each side of the inner eyepiece.
Remove the two 3.6 mm black screws from the outer piece.
5 andere personen hebben deze handleiding voltooid.
