Ga door naar hoofdinhoud
Canon EOS 20D Rear Case Replacement
Wat je nodig hebt
  1. Canon EOS 20D Rear Case Replacement, Remove the eyepiece cap: stap 1, afbeelding 1 van 2 Canon EOS 20D Rear Case Replacement, Remove the eyepiece cap: stap 1, afbeelding 2 van 2
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Canon EOS 20D Rear Case Replacement, Remove screws from under the eyepiece cap: stap 2, afbeelding 1 van 1
    • Remove the two screws hidden under the viewfinder eyepiece cap.
  3. Canon EOS 20D Rear Case Replacement, Remove hidden screw and other visible screw: stap 3, afbeelding 1 van 3 Canon EOS 20D Rear Case Replacement, Remove hidden screw and other visible screw: stap 3, afbeelding 2 van 3 Canon EOS 20D Rear Case Replacement, Remove hidden screw and other visible screw: stap 3, afbeelding 3 van 3
    • Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
    • Once removed, a hidden screw is revealed.
    • Remove both screws from the rear of the camera.
  4. Canon EOS 20D Rear Case Replacement, Remove bottom screws: stap 4, afbeelding 1 van 1
    • Remove the two indicated screws from the bottom of the camera.
  5. Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: stap 5, afbeelding 1 van 3 Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: stap 5, afbeelding 2 van 3 Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: stap 5, afbeelding 3 van 3
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off, now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Alec M
1.339 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 28
Altijd: 1,576
