Ga door naar hoofdinhoud
Canon ELPH Z3 Camera Battery Replacement
  1. Canon ELPH Z3 Camera Battery  Replacement, Battery: stap 1, afbeelding 1 van 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: stap 1, afbeelding 2 van 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place the camera face down on a flat surface ( lens facing down).
    • Press firmly on the battery latch that is marked.
    • Slide the battery latch to the right to expose battery.
    • Detach the battery latch completely from the camera.
  2. Canon ELPH Z3 Camera Battery  Replacement: stap 2, afbeelding 1 van 2 Canon ELPH Z3 Camera Battery  Replacement: stap 2, afbeelding 2 van 2
    • If the battery is leaking acid. Please proceed with extreme caution. You may sustain injury!
    • Remove the battery with a piece of double sided tape if it is leaking.
    • Use a Q-tip with a small amount of rubbing alcohol to clean battery connections.
    • Remove the existing battery using your fingers.
Conclusie
Nathan Barros
1 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-7, Catania Fall 2016 Lid van UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 1,148
