Inleiding
If you're having issues as a result of a dirty or faulty white document mat, this is where you will want to begin.
To remove the white document mat, you must:
- Carefully rip out the foam that's glued onto the cover.
- Glue in the replacement document mat.
Wat je nodig hebt
To reassemble your device, ensure that the white document mat is firmly glued on.
Één andere persoon heeft deze handleiding voltooid.
