Inleiding
If you're encountering issues as a result from the scanner bed, this is where you will want to start.
To replace the glass scanner bed, you must:
- Remove the two plastic bars that holds the scanner bed in place.
- Carefully remove the glass scanner bed to add the replacement.
Wat je nodig hebt
Open up your Canon CanoScan N670U to an upright position.
Één andere persoon heeft deze handleiding voltooid.
