Ga door naar hoofdinhoud
Canon 7210 Fan Replacement
Wat je nodig hebt
  1. Canon 7210 Fan Replacement, Exterior Shell: stap 1, afbeelding 1 van 2 Canon 7210 Fan Replacement, Exterior Shell: stap 1, afbeelding 2 van 2
    • Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
  2. Canon 7210 Fan Replacement: stap 2, afbeelding 1 van 3 Canon 7210 Fan Replacement: stap 2, afbeelding 2 van 3 Canon 7210 Fan Replacement: stap 2, afbeelding 3 van 3
    • Gently lift up on the shell with both hands, from the back to the front.
    • The shell will still be attached by a small cord in the front, so be careful not to tear it loose.
  3. Canon 7210 Fan Replacement, Fan: stap 3, afbeelding 1 van 1
    • Remove the two 7mm Phillips #0 screws that attach the fan to the motherboard of the projector.
  4. Canon 7210 Fan Replacement: stap 4, afbeelding 1 van 1
    • Remove the fan by pulling up gently from the top.
    • Be careful to not pull too hard or quickly, since the fan is still attached to the projector with some other wires.
  5. Canon 7210 Fan Replacement: stap 5, afbeelding 1 van 1
    • Remove the 7mm Phillips #0 screw that fastens the black ground wire connected to the fan and the projector.
  6. Canon 7210 Fan Replacement: stap 6, afbeelding 1 van 1
    • Peel the sticker up on the back of the fan to expose the port where the red, white, and black wires are attached.
    • The wires will need to be cut with small wire cutters in order to completely remove the fan.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
William Christian
331 Reputatie
3 handleidingen geschreven
USF Tampa, Team 9-3, Lacy Fall 2016 Lid van USF Tampa, Team 9-3, Lacy Fall 2016
USFT-LACY-F16S9G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 313
