Ga door naar hoofdinhoud
Canary CAN100USBK Audio and USB PCB Board Replacement
Wat je nodig hebt
  1. Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: stap 1, afbeelding 1 van 2 Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: stap 1, afbeelding 2 van 2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Audio and USB PCB Board Replacement: stap 2, afbeelding 1 van 1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Audio and USB PCB Board Replacement: stap 3, afbeelding 1 van 3 Canary CAN100USBK Audio and USB PCB Board Replacement: stap 3, afbeelding 2 van 3 Canary CAN100USBK Audio and USB PCB Board Replacement: stap 3, afbeelding 3 van 3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Audio and USB PCB Board Replacement: stap 4, afbeelding 1 van 2 Canary CAN100USBK Audio and USB PCB Board Replacement: stap 4, afbeelding 2 van 2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Audio and USB PCB Board Replacement: stap 5, afbeelding 1 van 2 Canary CAN100USBK Audio and USB PCB Board Replacement: stap 5, afbeelding 2 van 2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Audio and USB PCB Board Replacement, Ethernet PCB Board: stap 6, afbeelding 1 van 1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Audio and USB PCB Board Replacement: stap 7, afbeelding 1 van 2 Canary CAN100USBK Audio and USB PCB Board Replacement: stap 7, afbeelding 2 van 2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Audio and USB PCB Board Replacement: stap 8, afbeelding 1 van 1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
  9. Canary CAN100USBK Audio and USB PCB Board Replacement, Audio and USB PCB Board: stap 9, afbeelding 1 van 1
    • Using your fingernails, wiggle the power connector back and forth until it becomes loose.
    • Pull the power connector straight out of the socket.
    • Pull only on the power connector and not the wires themselves to prevent damage.
  10. Canary CAN100USBK Audio and USB PCB Board Replacement: stap 10, afbeelding 1 van 3 Canary CAN100USBK Audio and USB PCB Board Replacement: stap 10, afbeelding 2 van 3 Canary CAN100USBK Audio and USB PCB Board Replacement: stap 10, afbeelding 3 van 3
    • Use the spudger to pry up the retaining flap of the ZIF connector.
    • Disconnect the ribbon cable.
  11. Canary CAN100USBK Audio and USB PCB Board Replacement: stap 11, afbeelding 1 van 1
    • Remove the two Phillips #0 5mm screws.
  12. Canary CAN100USBK Audio and USB PCB Board Replacement: stap 12, afbeelding 1 van 2 Canary CAN100USBK Audio and USB PCB Board Replacement: stap 12, afbeelding 2 van 2
    • Pull the board away from the bottom casing by lifting the end closest to the chimney up.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kristopher Gates
399 Reputatie
3 handleidingen geschreven
USF Tampa, Team S1-G2, Nance Spring 2017 Lid van USF Tampa, Team S1-G2, Nance Spring 2017
USFT-NANCE-S17S1G2
4 Leden
16 handleidingen geschreven
2 opmerkingen
Hello great tutorial I have a problem with the usb on mine.
Where did you buy the PCB from?
craig perrin - Antwoord
nice guide, need to buy the ep-cnc01bb-02 board which has the micro usb on it as mine is worn out... any ideas?
Billy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 801
