Ga door naar hoofdinhoud
Campbell Hausfeld FP204800 Thumb Screw Drain Replacement
Wat je nodig hebt
  1. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Remove Thumb Screw Drain: stap 1, afbeelding 1 van 1
    • Remove the thumb screw drain from the bottom of the compressor using a Smart Wrench.
    • The thumb screw may not easily be removed due to corrosion.
  2. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Apply Teflon Tape: stap 2, afbeelding 1 van 1
    • Apply teflon tape to the replacement thumb screw drain.
    • The teflon tape should be wound tightly around the entire threaded portion of the thumb screw drain.
    • When you reassemble the thumb screw drain on the compressor, make sure to fully tighten it using a Smart Wrench.
Conclusie
Eric
409 Reputatie
3 handleidingen geschreven
Cal Poly, Team 14-29, Maness Fall 2014 Lid van Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 377
