Ga door naar hoofdinhoud
Campbell Hausfeld FP204800 Pressure Gauge Replacement
Wat je nodig hebt
  1. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: stap 1, afbeelding 1 van 3 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: stap 1, afbeelding 2 van 3 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: stap 1, afbeelding 3 van 3
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: stap 2, afbeelding 1 van 2 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: stap 2, afbeelding 2 van 2
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: stap 3, afbeelding 1 van 1
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the On/Off Switch Wiring: stap 4, afbeelding 1 van 1
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: stap 5, afbeelding 1 van 2 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: stap 5, afbeelding 2 van 2
    • Using a Smart Wrench, remove the old/broken pressure gauge or gauges.
Conclusie
Eric
409 Reputatie
3 handleidingen geschreven
Cal Poly, Team 14-29, Maness Fall 2014 Lid van Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 24
Altijd: 1,000
