Ga door naar hoofdinhoud
Cambridge SoundWorks OontZ Angle Plus Speakers Replacement
Wat je nodig hebt
  1. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Rubber Casing: stap 1, afbeelding 1 van 1
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 2, afbeelding 1 van 1
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 3, afbeelding 1 van 1
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 4, afbeelding 1 van 1
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speaker Grill: stap 5, afbeelding 1 van 1
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 6, afbeelding 1 van 1
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 7, afbeelding 1 van 1
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 8, afbeelding 1 van 1
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 9, afbeelding 1 van 1
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 10, afbeelding 1 van 2 Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 10, afbeelding 2 van 2
    • Finally, bend the speaker cover upward and it will slide out.
  11. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speakers: stap 11, afbeelding 1 van 1
    • With some force, push the motherboard straight in toward the center of the device.
  12. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 12, afbeelding 1 van 1
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This makes the motherboard fit in the groove rather tight.
  13. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 13, afbeelding 1 van 1
    • Unplug the speaker's connector from the motherboard.
  14. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 14, afbeelding 1 van 1
    • Unscrew the eight screws holding the speakers in place.
  15. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 15, afbeelding 1 van 1
    • Desolder the the wires connected to the back side of both speakers.
  16. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: stap 16, afbeelding 1 van 1
    • Carefully push the speakers out one at a time.
Conclusie
David Rice
161 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-1, Nance Spring 2016 Lid van USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,894
