Ga door naar hoofdinhoud
Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement
Wat je nodig hebt
  1. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Rubber Casing: stap 1, afbeelding 1 van 1
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: stap 2, afbeelding 1 van 1
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: stap 3, afbeelding 1 van 1
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: stap 4, afbeelding 1 van 1
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Speaker Grill: stap 5, afbeelding 1 van 1
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: stap 6, afbeelding 1 van 1
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: stap 7, afbeelding 1 van 1
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: stap 8, afbeelding 1 van 1
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: stap 9, afbeelding 1 van 1
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: stap 10, afbeelding 1 van 2 Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: stap 10, afbeelding 2 van 2
    • Finally, bend the speaker cover upward and it will slide out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Farshad Mohebban
524 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-1, Nance Spring 2016 Lid van USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 950
