Ga door naar hoofdinhoud
Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
Wat je nodig hebt
  1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: stap 1, afbeelding 1 van 2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: stap 1, afbeelding 2 van 2
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
  2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: stap 2, afbeelding 1 van 1
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
  3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 3, afbeelding 1 van 1
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
  4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 4, afbeelding 1 van 1
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
  5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
  6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 6, afbeelding 1 van 1
    • Separate the battery from the bottom plate and set the bottom plate aside.
  7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 7, afbeelding 1 van 1
    • With some force, push the motherboard straight in toward the center of the device.
  8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 8, afbeelding 1 van 1
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
  9. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 9, afbeelding 1 van 1
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
  10. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Unplug the wires that connect the speakers to the motherboard.
  11. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 11, afbeelding 1 van 1
    • Unplug the thin white cable connected to the buttons.
  12. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 12, afbeelding 1 van 2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: stap 12, afbeelding 2 van 2
    • Desolder the wires that connect the LED to the motherboard.
Conclusie
Farshad Mohebban
524 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-1, Nance Spring 2016 Lid van USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,856
