Ga door naar hoofdinhoud
Calculator is Stuck While Graphing
  1. Calculator is Stuck While Graphing, Calculator is Stuck While Graphing: stap 1, afbeelding 1 van 1
    • To cancel the graphing process, press the "ON" button.
  2. Calculator is Stuck While Graphing: stap 2, afbeelding 1 van 3 Calculator is Stuck While Graphing: stap 2, afbeelding 2 van 3 Calculator is Stuck While Graphing: stap 2, afbeelding 3 van 3
    • Go to "Zoom." Navigate to and highlight "ZoomFit" then press "Enter." Doing so will automatically set your graphing window to the most appropriate dimensions.
  3. Calculator is Stuck While Graphing: stap 3, afbeelding 1 van 1
    • If you are graphing complex equations, multiple equations, or a combination of the two, it may take anywhere from 1 minute to 5 minutes to graph.
    • The bar on the top right corner indicates the calculator is graphing.
  4. Calculator is Stuck While Graphing: stap 4, afbeelding 1 van 2 Calculator is Stuck While Graphing: stap 4, afbeelding 2 van 2
    • If you feel that your graph is taking too long, you can change the step resolution to a bigger number. To do so, press "Window" and change "Xres" to a value between 1 and 8. A bigger Xres value will graph more quickly.
Conclusie
It is always a good idea to make sure your graph will display a good window.
John Baek
31 Reputatie
4 handleidingen geschreven
Cal Poly, Team 7-52, Forte Fall 2012 Lid van Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 31
Altijd: 1,897
