Ga door naar hoofdinhoud
Cabinet Door Butt Hinge Replacement
Wat je nodig hebt
  1. Cabinet Door Butt Hinge Replacement, Cabinet Door Butt Hinge: stap 1, afbeelding 1 van 1
    • Determine where the cabinet needs repair: on the top or bottom hinge.
  2. Cabinet Door Butt Hinge Replacement: stap 2, afbeelding 1 van 1
    • Measure the hinge to make sure you have the correct size of your butt hinge.
    • Measure the distance between the screws and the height and width of the hinge to get the correct hinge.
  3. Cabinet Door Butt Hinge Replacement: stap 3, afbeelding 1 van 1
    • Remove the screws from the door with a Phillips #00 screwdriver and remove the hinge.
    • Keep the screws nearby; you will need them later.
  4. Cabinet Door Butt Hinge Replacement: stap 4, afbeelding 1 van 1
    • Align the cabinet door to stand straight with any surrounding cabinets.
  5. Cabinet Door Butt Hinge Replacement: stap 5, afbeelding 1 van 1
    • Place the new hinge where the previous one was. Align the holes together.
  6. Cabinet Door Butt Hinge Replacement: stap 6, afbeelding 1 van 1
    • Tighten the hinge into place using the same screws with your Phillips #00 screwdriver.
Conclusie
If the door closes parallel to any surrounding cabinets, your fix is complete!
Laura Carew
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 42
Altijd: 328
