Inleiding
Hier repareer ik de volumeregeling van de roterende encoder. Het is een veelvoorkomend probleem dat ze vuil worden.
Wat je nodig hebt
Verwijder de flexibele lintkabels voor gemakkelijke toegang
Verwijder het cassettedeck (dit is om toegang te krijgen tot de schroef eronder)
Verwijder de schroeven (u moet het cassettedeck verwijderen om toegang te krijgen tot de oranje schroef)
Til voorzichtig een kant van het cassettedeck op en verwijder de printplaat.
Volg deze instructies in omgekeerde volgorde om uw apparaat weer in elkaar te zetten.
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Toon Konings helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
2 opmerkingen
Hi Jacco, thanks for this guide. What device is this? As the instructions for disassembly are somewhat specific, this could be interesting. For cleaning the encoder, you seriously recommend to do that using a screwdriver? I find the spring contacts inside these encoders rather delicate typically and they would easily take damage if the wrong tool is used for cleaning. I must recommend to use 1) a lot of care, 2) nothing that is tougher than cotton buds, 3) alcohol, and 4) contact spray eventually to keep things clean and coated against future oxidation. Usually there is no need for scrubbing if contacts are gold plated. Oxidation might be an issue otherwise but that is best removed with chemical anti-oxidation agents, and if that does not help, a (very) soft metal brush, or maybe very fine grain sandpaper, applied with as little pressure as possible of course. A screwdriver will easily scratch surfaces or bend contacts, both of which will cause the encoder to drop out again sooner than later.
Hi,
I have a CMT CP1 That turns on the screen works everything I the screen seem working. But when I try to launch tuner or cd or tape nothing is working. The display says the cd is opening then nothing it says it closing but physically doesn't do anything
