Ga door naar hoofdinhoud
CM Storm QuickFire Rapid O-ring: Large Keycap Installation
Wat je nodig hebt
  1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: stap 1, afbeelding 1 van 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: stap 1, afbeelding 2 van 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: stap 1, afbeelding 3 van 3
  2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: stap 2, afbeelding 1 van 1
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: stap 3, afbeelding 1 van 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: stap 3, afbeelding 2 van 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: stap 3, afbeelding 3 van 3
    • Remove the plastic rings from the keycap.
  4. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: stap 4, afbeelding 1 van 2 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: stap 4, afbeelding 2 van 2
    • Place the O-rings around the nubs underneath the keycap at each circled locations.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shiva Empranthiri
781 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-23, Maness Fall 2014 Lid van Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Leden
12 handleidingen geschreven
Één opmerking
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 1,919
