Ga door naar hoofdinhoud
CHI Spin N Curl Rotating Curler Rotating Barrel Replacement
Wat je nodig hebt
  1. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Power Cord: stap 1, afbeelding 1 van 1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 2, afbeelding 1 van 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 3, afbeelding 1 van 2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 3, afbeelding 2 van 2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 4, afbeelding 1 van 2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 4, afbeelding 2 van 2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 5, afbeelding 1 van 3 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 5, afbeelding 2 van 3 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 5, afbeelding 3 van 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Heating Element: stap 6, afbeelding 1 van 1
    • After following steps to open the CHI Spin N Curl, locate the heating element.
    • Remove screws on both sides of the heating element.
    • Once screws have been removed, then remove the heating element component.
    • Replace heating element once the original has been removed.
  7. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Rotating Barrel: stap 7, afbeelding 1 van 1
    • Remove all visible screws located near the barrel of the CHI Spin N Curl utilizing a Phillips #00 screwdriver.
    • Screws will be small and black.
  8. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 8, afbeelding 1 van 2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: stap 8, afbeelding 2 van 2
    • Remove all screws located near wires using a Phillips #00 screwdriver.
    • Once all surrounding screws have been removed, detach the rotating barrel.
    • Gently remove the rotating barrel and replace once removed.
Conclusie
Annalise White
530 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 604
