Inleiding
If you need replace the battery of your CASIO fx-82ES PLUS calculator, follow this guide. A calculator with low battery power may cause dim display or even the inability to turn it on. The calculator battery will drain over time and with repeated use.
Wat je nodig hebt
Turn off the calculator before you begin by pressing the shift button first and at the same time press the AC button.
3 andere personen hebben deze handleiding voltooid.
