Ga door naar hoofdinhoud
CASIO fx-50FH II Scientific Calculator Battery Replacement
Wat je nodig hebt
  1. CASIO fx-50FH II Scientific Calculator Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • To turn the calculator off, first press the "shift" button.
    • Release the "shift" button, then press the "AC" button.
  2. CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 2, afbeelding 1 van 2 CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 2, afbeelding 2 van 2
    • Place the calculator face down, then use a Phillips #00 screwdriver to remove the single screw securing the battery hatch in the top right corner.
  3. CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 3, afbeelding 1 van 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 3, afbeelding 2 van 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 3, afbeelding 3 van 3
    • Push the battery hatch to the right until it slides off.
  4. CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 4, afbeelding 1 van 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 4, afbeelding 2 van 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 4, afbeelding 3 van 3
    • Put on a pair of protective gloves before handling the battery to eliminate the risk of chemical burns.
    • Insert the tip of a spudger into the indent on the right-hand side of the battery to lift the edge of the battery up.
    • Lift the battery up and out.
  5. CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 5, afbeelding 1 van 1
    • Inspect the battery compartment any alkaline residue.
    • If no residue is present, skip to Step 7.
  6. CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 6, afbeelding 1 van 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 6, afbeelding 2 van 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 6, afbeelding 3 van 3
    • Use a cotton swab dabbed with white vinegar to wipe the alkaline off the battery compartment.
    • Use a dry cotton swab to remove the vinegar and alkaline residues.
    • Let the battery compartment dry completely.
  7. CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 7, afbeelding 1 van 1
    • Insert a new LR44 1.5V alkaline button battery into the compartment, with the positive sign facing up.
  8. CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 8, afbeelding 1 van 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 8, afbeelding 2 van 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 8, afbeelding 3 van 3
    • Reattach the battery hatch by sliding the hatch in from the right to the left.
  9. CASIO fx-50FH II Scientific Calculator Battery Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips #00 to secure the screw.
Conclusie
You have successfully replaced the battery of  a CASIO fx-50FH II Scientific Calculator!
Één andere persoon heeft deze handleiding voltooid.
Cheuk Wai Chan
196 Reputatie
1 Handleiding geschreven
York University, Team M-4, Allen Summer 2022 Lid van York University, Team M-4, Allen Summer 2022
YORK-ALLEN-SU22SMG4
1 Lid
3 handleidingen geschreven
2Gids Commentaar
Very nice guide! I found the pictures to be very good and corresponding to the steps very well.
Frank Loi - Antwoord
Thank you for the steps. I followed the steps and managed to salvage my calculator which I almost had to throw away. This has helped reduce waste. :)
Nancy Yeo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 67
Afgelopen 30 dagen: 270
Altijd: 5,531
