Ga door naar hoofdinhoud
CASIO CDP-230R Panels Replacement
Wat je nodig hebt
  1. CASIO CDP-230R Panels Replacement, Panels: stap 1, afbeelding 1 van 3 CASIO CDP-230R Panels Replacement, Panels: stap 1, afbeelding 2 van 3 CASIO CDP-230R Panels Replacement, Panels: stap 1, afbeelding 3 van 3
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
  2. CASIO CDP-230R Panels Replacement: stap 2, afbeelding 1 van 3 CASIO CDP-230R Panels Replacement: stap 2, afbeelding 2 van 3 CASIO CDP-230R Panels Replacement: stap 2, afbeelding 3 van 3
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
  3. CASIO CDP-230R Panels Replacement: stap 3, afbeelding 1 van 3 CASIO CDP-230R Panels Replacement: stap 3, afbeelding 2 van 3 CASIO CDP-230R Panels Replacement: stap 3, afbeelding 3 van 3
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
  4. CASIO CDP-230R Panels Replacement: stap 4, afbeelding 1 van 3 CASIO CDP-230R Panels Replacement: stap 4, afbeelding 2 van 3 CASIO CDP-230R Panels Replacement: stap 4, afbeelding 3 van 3
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
  5. CASIO CDP-230R Panels Replacement: stap 5, afbeelding 1 van 3 CASIO CDP-230R Panels Replacement: stap 5, afbeelding 2 van 3 CASIO CDP-230R Panels Replacement: stap 5, afbeelding 3 van 3
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
  6. CASIO CDP-230R Panels Replacement: stap 6, afbeelding 1 van 3 CASIO CDP-230R Panels Replacement: stap 6, afbeelding 2 van 3 CASIO CDP-230R Panels Replacement: stap 6, afbeelding 3 van 3
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
  7. CASIO CDP-230R Panels Replacement: stap 7, afbeelding 1 van 3 CASIO CDP-230R Panels Replacement: stap 7, afbeelding 2 van 3 CASIO CDP-230R Panels Replacement: stap 7, afbeelding 3 van 3
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
  8. CASIO CDP-230R Panels Replacement: stap 8, afbeelding 1 van 3 CASIO CDP-230R Panels Replacement: stap 8, afbeelding 2 van 3 CASIO CDP-230R Panels Replacement: stap 8, afbeelding 3 van 3
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
Conclusie
Areli Reyes
545 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G2, Livingston Fall 2017 Lid van Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 907
