Ga door naar hoofdinhoud
C-Clamp Sternum Strap Replacement
  1. C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: stap 1, afbeelding 1 van 2 C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: stap 1, afbeelding 2 van 2
    • Locate the sternum strap that has come off the pack.
    • Replacements for this style of sternum strap are not currently available, so if part or all of the sternum strap is missing, reach out to Patagonia for alternative options.
    Vraag FixBot
  2. C-Clamp Sternum Strap Replacement: stap 2, afbeelding 1 van 3 C-Clamp Sternum Strap Replacement: stap 2, afbeelding 2 van 3 C-Clamp Sternum Strap Replacement: stap 2, afbeelding 3 van 3
    • The 'c-clamp' piece of the sternum strap fits over a plastic tube or ‘rail’ that is inside the backpack strap. At the bottom of this rail there is a fabric flap.
    • Pull back the fabric flap to expose where the rail ends. This is where the c-clamp was designed to be slid on and off.
    Vraag FixBot
    • At the exposed area at the base of the rail, slide the c-clamp back onto the rail.
    • Pull tightly on the fabric flap to expose the area.
    • Maneuver as if parallel parking a car. Start at an angle, slide partially onto the rail, and then straighten out.
    • This can be difficult to do, don’t be shy using some muscle!
    • Repeat the steps above on the other backpack strap.
    Vraag FixBot
  3. C-Clamp Sternum Strap Replacement: stap 4, afbeelding 1 van 2 C-Clamp Sternum Strap Replacement: stap 4, afbeelding 2 van 2
    • Slide the sternum strap to your desired position.
    • Hit the trails with your newly attached sternum strap!
    Vraag FixBot
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Zach Mueller
1.762 Reputatie
9 handleidingen geschreven
Patagonia Lid van Patagonia
Community
9 Leden
151 handleidingen geschreven
2Gids Commentaar
This is helpful, except where do I find the replacement part! I contacted Patagonia and they no longer make it; they said to try a local sporting goods store or to send to Patagonia and they'll sew on a new daisy-chain version. My local REI does not have these parts either. Bummer!
Jornywar - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 190
Altijd: 4,340
