Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Replacing the button board requires you to almost completely disassemble the device and solder several points. The process is feasible even if one lacks soldering experience.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:iOpener$19.99
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
Remove the four 6 mm screws that secure the button controller PCB to the rest of the device; you will need a Phillips #2 driver for this task.
Lift the PCB away from the rest of the device.
