Inleiding
Follow this guide to remove and replace or repair the spout on a Bush pump.
Wat je nodig hebt
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
Use a pipe wrench to loosen and remove the pump spout.
Place the spout on a clean surface to prevent any contamination.
Één andere persoon heeft deze handleiding voltooid.
