Ga door naar hoofdinhoud
Bush Pump Riser Main Slider Replacement
Wat je nodig hebt
  1. Bush Pump Riser Main Slider Replacement, Head and Handle: stap 1, afbeelding 1 van 2 Bush Pump Riser Main Slider Replacement, Head and Handle: stap 1, afbeelding 2 van 2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Riser Main Slider Replacement: stap 2, afbeelding 1 van 2 Bush Pump Riser Main Slider Replacement: stap 2, afbeelding 2 van 2
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Riser Main Slider Replacement: stap 3, afbeelding 1 van 2 Bush Pump Riser Main Slider Replacement: stap 3, afbeelding 2 van 2
    • Pull the two lever arms away from the slider.
  4. Bush Pump Riser Main Slider Replacement: stap 4, afbeelding 1 van 2 Bush Pump Riser Main Slider Replacement: stap 4, afbeelding 2 van 2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Riser Main Slider Replacement: stap 5, afbeelding 1 van 3 Bush Pump Riser Main Slider Replacement: stap 5, afbeelding 2 van 3 Bush Pump Riser Main Slider Replacement: stap 5, afbeelding 3 van 3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Riser Main Slider Replacement: stap 6, afbeelding 1 van 1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
  7. Bush Pump Riser Main Slider Replacement, Riser Main Slider: stap 7, afbeelding 1 van 2 Bush Pump Riser Main Slider Replacement, Riser Main Slider: stap 7, afbeelding 2 van 2
    • Firmly lift the riser main slider with two hands.
    • Use caution not to drop the riser main, as this can damage the pump cylinder.
  8. Bush Pump Riser Main Slider Replacement: stap 8, afbeelding 1 van 3 Bush Pump Riser Main Slider Replacement: stap 8, afbeelding 2 van 3 Bush Pump Riser Main Slider Replacement: stap 8, afbeelding 3 van 3
    • Use a pipe wrench to fully loosen the above grade riser pipe.
  9. Bush Pump Riser Main Slider Replacement: stap 9, afbeelding 1 van 3 Bush Pump Riser Main Slider Replacement: stap 9, afbeelding 2 van 3 Bush Pump Riser Main Slider Replacement: stap 9, afbeelding 3 van 3
    • Lift the slider and riser main pipe.
    • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
    • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  10. Bush Pump Riser Main Slider Replacement: stap 10, afbeelding 1 van 3 Bush Pump Riser Main Slider Replacement: stap 10, afbeelding 2 van 3 Bush Pump Riser Main Slider Replacement: stap 10, afbeelding 3 van 3
    • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
  11. Bush Pump Riser Main Slider Replacement: stap 11, afbeelding 1 van 2 Bush Pump Riser Main Slider Replacement: stap 11, afbeelding 2 van 2
    • Remove the riser main slider, and inspect it for wear and tear.
    • Set the slider in a sanitary place to prevent contamination.
Conclusie
Jake Devincenzi
117.301 Reputatie
57 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 170
