Ga door naar hoofdinhoud
Bulova Precisionist 96B252 Link Replacement
Wat je nodig hebt
  1. Bulova Precisionist 96B252 Link Replacement, Link: stap 1, afbeelding 1 van 1
    • Open the watchband and locate the arrows that are on the inside edge of the band.
  2. Bulova Precisionist 96B252 Link Replacement: stap 2, afbeelding 1 van 1
    • Place the watch onto the watch holder with the arrows pointing down.
  3. Bulova Precisionist 96B252 Link Replacement: stap 3, afbeelding 1 van 2 Bulova Precisionist 96B252 Link Replacement: stap 3, afbeelding 2 van 2
    • Align the 0.8 mm pin puncher to the link hole you want to remove.
    • Lightly tap the pin puncher with the soft side of the hammer until the pin comes out
    • The pin can be reused to attach the new link if it is not warped or damaged.
  4. Bulova Precisionist 96B252 Link Replacement: stap 4, afbeelding 1 van 1
    • Flip the watch so the arrows on the band are pointing up and away from the watch holder.
  5. Bulova Precisionist 96B252 Link Replacement: stap 5, afbeelding 1 van 3 Bulova Precisionist 96B252 Link Replacement: stap 5, afbeelding 2 van 3 Bulova Precisionist 96B252 Link Replacement: stap 5, afbeelding 3 van 3
    • Align the pinhole on the new link with the pinhole on the watch band.
    • Once the pin holes are lined up, position the pin over the holes
    • Use the soft side of the hammer to gently tap the pin into the links, connecting the new link to the watch.
  6. Bulova Precisionist 96B252 Link Replacement: stap 6, afbeelding 1 van 1
    • Once the pin is smoothly inserted into the band, try the watch on to ensure the new links are aligned and securely in place.
Conclusie
To reassemble your watch, follow these instructions in reverse order.
Michael
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 67
Altijd: 293
