Ga door naar hoofdinhoud
Brother PT-90 Personal Labeler Disassembly
Wat je nodig hebt
  1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: stap 1, afbeelding 1 van 2 Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: stap 1, afbeelding 2 van 2
    • Start with your device off. The screen should be blank and not displaying anything.
    • Turn the device over so it's resting face down.
    • You should be able to see the model name of the label-maker, as well as a window in which you can view the label cartridge.
  2. Brother PT-90 Personal Labeler Disassembly: stap 2, afbeelding 1 van 3 Brother PT-90 Personal Labeler Disassembly: stap 2, afbeelding 2 van 3 Brother PT-90 Personal Labeler Disassembly: stap 2, afbeelding 3 van 3
    • Using your thumb, press in and then upward on the fastener at the top of the device. The back of the device should come off easily.
    • Remove the 4 batteries located on the left side of the device.
  3. Brother PT-90 Personal Labeler Disassembly: stap 3, afbeelding 1 van 3 Brother PT-90 Personal Labeler Disassembly: stap 3, afbeelding 2 van 3 Brother PT-90 Personal Labeler Disassembly: stap 3, afbeelding 3 van 3
    • To remove the label cartridge from the device, use a plastic opening tool from your iFixit tool kit.
  4. Brother PT-90 Personal Labeler Disassembly: stap 4, afbeelding 1 van 3 Brother PT-90 Personal Labeler Disassembly: stap 4, afbeelding 2 van 3 Brother PT-90 Personal Labeler Disassembly: stap 4, afbeelding 3 van 3
    • Attach the J1 Screwdriver Bit to the extension tool from your tool kit.
    • Remove all of the screws from the back of the device.
  5. Brother PT-90 Personal Labeler Disassembly: stap 5, afbeelding 1 van 2 Brother PT-90 Personal Labeler Disassembly: stap 5, afbeelding 2 van 2
    • Once the screws have been removed, press as shown on the fastener.
    • Carefully open the device.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Tessa Hathaway
148 Reputatie
1 Handleiding geschreven
University of Maine, Team 2-1, Diaz Fall 2016 Lid van University of Maine, Team 2-1, Diaz Fall 2016
UMAINE-DIAZ-F16S2G1
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 853
