Ga door naar hoofdinhoud
Brother PT-1290 Tape Cassette Replacement
  1. Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: stap 1, afbeelding 1 van 2 Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: stap 1, afbeelding 2 van 2
    • There is a plastic tab located on the back of the label maker near the top. The tab has ridges on it to help you identify where to press. Push on this tab to release the back of the label maker.
    • Gently pull the label maker apart - it will split in half.
    • Be careful! The electronics inside are very sensitive and easily damaged.
  2. Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: stap 2, afbeelding 1 van 2 Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: stap 2, afbeelding 2 van 2
    • Remove the AAA batteries before you proceed on to replacing the tape cassette.
  3. Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: stap 3, afbeelding 1 van 2 Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: stap 3, afbeelding 2 van 2
    • Align and insert a new tape cassette. Make sure the center of the cassette snaps into place. The tape must feed between the tape guides.
    • If the ribbon has become too loose, use your finger to turn the white wheel in the direction of the arrow on the tape cassette. This will wind up any excess tape.
    • Only use Brother TZ tapes with this machine.
  4. Brother PT-1290 Tape Cassette Replacement, Evaluating: stap 4, afbeelding 1 van 1
    • Place the batteries back inside, then close the cover.
    • Check that all six batteries are inserted correctly.
  5. Brother PT-1290 Tape Cassette Replacement, Feeding Tape.: stap 5, afbeelding 1 van 1
    • To test the new cassette, make a new label. Press "Shift" and "Print" to feed the tape, then use the cutting lever on the upper-right corner of the machine.
Conclusie
Lorraine Canez
318 Reputatie
3 handleidingen geschreven
Gateway, Team 1-4, Johnson Fall 2014 Lid van Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 Leden
6 handleidingen geschreven
Één opmerking
Wie wird die Kassette eingesetzt
Uwe Seiler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 33
Altijd: 19,744
