Inleiding
In this guide, you will see how to fix your broken/damaged face plate on your Brother PT-1290.
Wat je nodig hebt
Turn the device to its side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
Now that you have removed your keyboard. Turn the device over carefully.
Pop of LCD black cover.
Use the spudger to gently press out the LCD screen.
Change out old damaged face plate with your new face plate.
Bijna klaar!
Conclusie
