Ga door naar hoofdinhoud
Brother PT-110 Print Roller Lever Replacement
Wat je nodig hebt
  1. Brother PT-110 Print Roller Lever Replacement, Batteries: stap 1, afbeelding 1 van 2 Brother PT-110 Print Roller Lever Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Print Roller Lever Replacement: stap 2, afbeelding 1 van 1
    • Remove the batteries.
  3. Brother PT-110 Print Roller Lever Replacement, Back Plate: stap 3, afbeelding 1 van 2 Brother PT-110 Print Roller Lever Replacement, Back Plate: stap 3, afbeelding 2 van 2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Print Roller Lever Replacement: stap 4, afbeelding 1 van 1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Print Roller Lever Replacement: stap 5, afbeelding 1 van 1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Print Roller Lever Replacement: stap 6, afbeelding 1 van 1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Print Roller Lever Replacement: stap 7, afbeelding 1 van 2 Brother PT-110 Print Roller Lever Replacement: stap 7, afbeelding 2 van 2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Print Roller Lever Replacement: stap 8, afbeelding 1 van 3 Brother PT-110 Print Roller Lever Replacement: stap 8, afbeelding 2 van 3 Brother PT-110 Print Roller Lever Replacement: stap 8, afbeelding 3 van 3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Print Roller Lever Replacement, Print Roller Lever: stap 9, afbeelding 1 van 1
    • Using the metal spudger, swivel the pin so that the print roller lever loosens.
  10. Brother PT-110 Print Roller Lever Replacement: stap 10, afbeelding 1 van 1
    • Gently pull the print roller lever out.
Conclusie
Kimberly Larsen
237 Reputatie
5 handleidingen geschreven
IUPUI, Team 1-1, Harley Fall 2016 Lid van IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Leden
7 handleidingen geschreven
5 opmerkingen
Hi everybody ,does anyone knows were I can by such a lever ?
TBH
Daniel Verkest - Antwoord
BONJOUR, (I’m French)
Same question: does anyone knows were I can by such a lever ?
Pegase M - Antwoord
Did anyone find a source for this part?
Erik Carlson - Antwoord
Unfortunately very discontinued. Until someone adds it to thingverse there's not much that can be done.
UN8026001 ROLLER HOLDER ASSY PT100/110
UN8031001 ROLLER HOLDER SPRING PT100
UN8032000 ROLLER RELEASE LEVER PT100/110
Michael Krieger - Antwoord
I can fix these by using plastic weld to rebuild the edging. I was totally successful.
George Pede - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 24
Altijd: 1,665
