Ga door naar hoofdinhoud
Brother MFC-490CW Wireless module Replacement
Wat je nodig hebt
  1. Brother MFC-490CW Wireless module Replacement, Remove screws holding the front panel: stap 1, afbeelding 1 van 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: stap 2, afbeelding 1 van 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: stap 2, afbeelding 2 van 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: stap 2, afbeelding 3 van 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Wireless module Replacement, Remove the screw: stap 3, afbeelding 1 van 1
    • Unscrew the 14.1mm screw located at the left side of the device.
    • Unscrew the 12.1mm screw to the right of the 14.1mm screw.
  4. Brother MFC-490CW Wireless module Replacement: stap 4, afbeelding 1 van 3 Brother MFC-490CW Wireless module Replacement: stap 4, afbeelding 2 van 3 Brother MFC-490CW Wireless module Replacement: stap 4, afbeelding 3 van 3
    • Pry open the left front panel away from the printer
    • Be careful. The panel is attached with a data cable.
  5. Brother MFC-490CW Wireless module Replacement: stap 5, afbeelding 1 van 2 Brother MFC-490CW Wireless module Replacement: stap 5, afbeelding 2 van 2
    • Carefully unplug the connector attached to the device.
  6. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: stap 6, afbeelding 1 van 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: stap 6, afbeelding 2 van 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: stap 6, afbeelding 3 van 3
    • Separate the two clips that hold the module in place.
    • Lift up the module.
Conclusie
To reassemble your wireless module, follow these instructions in reverse order.
Matt
64 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-4, Miles Fall 2014 Lid van UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 1,664
