Ga door naar hoofdinhoud
Brother MFC-490CW Front Panel Replacement
Wat je nodig hebt
  1. Brother MFC-490CW Front Panel Replacement, Remove screws holding the front panel: stap 1, afbeelding 1 van 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: stap 2, afbeelding 1 van 3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: stap 2, afbeelding 2 van 3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: stap 2, afbeelding 3 van 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
Conclusie
To reassemble the front panel, follow these instructions in reverse order.
Matt
64 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-4, Miles Fall 2014 Lid van UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Leden
8 handleidingen geschreven
Één opmerking
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
Raymond Rinaldi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 1,722
