Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Brother HL-5240 Toner Cartridge Replacement
Wat je nodig hebt
  1. Brother HL-5240 Toner Cartridge Replacement, Drum Unit and Toner Cartridge: stap 1, afbeelding 1 van 1
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. Brother HL-5240 Toner Cartridge Replacement: stap 2, afbeelding 1 van 3 Brother HL-5240 Toner Cartridge Replacement: stap 2, afbeelding 2 van 3 Brother HL-5240 Toner Cartridge Replacement: stap 2, afbeelding 3 van 3
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
  3. Brother HL-5240 Toner Cartridge Replacement, Toner Cartridge: stap 3, afbeelding 1 van 3 Brother HL-5240 Toner Cartridge Replacement, Toner Cartridge: stap 3, afbeelding 2 van 3 Brother HL-5240 Toner Cartridge Replacement, Toner Cartridge: stap 3, afbeelding 3 van 3
    • The drum unit is the gray bottom half of the component in the picture, while the top black part is the toner cartridge.
    • Separate the toner cartridge from the drum unit by pressing down on the blue tab and gently lifting the toner cartridge up by the lift on the handle.
    • DO NOT TOUCH the roller bar on the toner cartridge, or the roller bar on the drum unit as illustrated in the pictures. This may cause a decrease in print quality.
  4. Brother HL-5240 Toner Cartridge Replacement: stap 4, afbeelding 1 van 3 Brother HL-5240 Toner Cartridge Replacement: stap 4, afbeelding 2 van 3 Brother HL-5240 Toner Cartridge Replacement: stap 4, afbeelding 3 van 3
    • Insert the toner cartridge into the new drum break by firmly sliding the cartridge into the drum unit. If installed correctly, the blue lever will be locked in a lifted position.
    • Be sure that the black nob located on the back of the toner cartridge is places inside the track located on the drum unit.
    • The third picture illustrates an incorrectly installed drum unit and toner cartridge, notice how the blue lever is down.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Tyler Davies
88 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-14, Forte Winter 2010 Lid van Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 Leden
10 handleidingen geschreven
2 opmerkingen
thanku for this useful information on how to replace toner cartridges for Brother HL-5240...its clear with the images used....most helpful indeed!!!
can also log on to http://www.tonertree.com for some exciting products!!!!
syed - Antwoord
Thank you for this article! I helped me a lot! I have bought this model of toner http://hardware.nl/printkop/brother/ph11... but when I tried to replace it I failed. Now I did it and my printer work like a new one. Thank you one more time!
Scott Waschlerner - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 11,963
