Ga door naar hoofdinhoud
Inleiding
This repair guide shows how to install a new toner cartridge.
Gereedschap
Geen gereedschap opgegeven.
Onderdelen
  1. Press the front cover release button.
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. With the front cover in the downward position, the drum & toner unit will be visible. Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer. Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
  3. The drum unit is the gray bottom half of the component in the picture, while the top black part is the toner cartridge. Separate the toner cartridge from the drum unit by pressing down on the blue tab and gently lifting the toner cartridge up by the lift on the handle. DO NOT TOUCH the roller bar on the toner cartridge, or the roller bar on the drum unit as illustrated in the pictures.  This may cause a decrease in print quality.
    • The drum unit is the gray bottom half of the component in the picture, while the top black part is the toner cartridge.
    • Separate the toner cartridge from the drum unit by pressing down on the blue tab and gently lifting the toner cartridge up by the lift on the handle.
    • DO NOT TOUCH the roller bar on the toner cartridge, or the roller bar on the drum unit as illustrated in the pictures. This may cause a decrease in print quality.
  4. Insert the toner cartridge into the new drum break by firmly sliding the cartridge into the drum unit. If installed correctly, the blue lever will be locked in a lifted position. Be sure that the black nob located on the back of the toner cartridge is places inside the track located on the drum unit. The third picture illustrates an incorrectly installed drum unit and toner cartridge, notice how the blue lever is down.
    • Insert the toner cartridge into the new drum break by firmly sliding the cartridge into the drum unit. If installed correctly, the blue lever will be locked in a lifted position.
    • Be sure that the black nob located on the back of the toner cartridge is places inside the track located on the drum unit.
    • The third picture illustrates an incorrectly installed drum unit and toner cartridge, notice how the blue lever is down.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Tyler Davies
88 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-14, Forte Winter 2010 Lid van Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 Leden
5 handleidingen geschreven
thanku for this useful information on how to replace toner cartridges for Brother HL-5240...its clear with the images used....most helpful indeed!!!
can also log on to http://www.tonertree.com for some exciting products!!!!
syed - Antwoord
Thank you for this article! I helped me a lot! I have bought this model of toner http://hardware.nl/printkop/brother/ph11... but when I tried to replace it I failed. Now I did it and my printer work like a new one. Thank you one more time!
Scott Waschlerner - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 11,403
