Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide tells you how to remove the drum & toner unit from the printer before you perform any maintenance.
  1. Press the front cover release button.
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. With the front cover in the downward position, the drum & toner unit will be visible. Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer. Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Guy Patterson
93 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-14, Forte Winter 2010 Lid van Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 8,129
