Ga door naar hoofdinhoud
Broken End of a Toe Post of a Flip Flop Replacement
Wat je nodig hebt
  1. Broken End of a Toe Post of a Flip Flop Replacement, Broken End of a Toe Post of a Flip Flop: stap 1, afbeelding 1 van 3 Broken End of a Toe Post of a Flip Flop Replacement, Broken End of a Toe Post of a Flip Flop: stap 1, afbeelding 2 van 3 Broken End of a Toe Post of a Flip Flop Replacement, Broken End of a Toe Post of a Flip Flop: stap 1, afbeelding 3 van 3
    • Make sure that your flip-flop is clean from dirt or stains.
  2. Broken End of a Toe Post of a Flip Flop Replacement: stap 2, afbeelding 1 van 2 Broken End of a Toe Post of a Flip Flop Replacement: stap 2, afbeelding 2 van 2
    • Use a marker to draw a small circle on the Anti-Skid Pads.
  3. Broken End of a Toe Post of a Flip Flop Replacement: stap 3, afbeelding 1 van 1
    • Use utility scissors to cut out the small circle.
  4. Broken End of a Toe Post of a Flip Flop Replacement: stap 4, afbeelding 1 van 1
    • Squeeze out super glue into a container.
    • You can wear gloves to avoid skin contact with glue.
  5. Broken End of a Toe Post of a Flip Flop Replacement: stap 5, afbeelding 1 van 1
    • Use a chopstick to apply the adhesive to the pad.
  6. Broken End of a Toe Post of a Flip Flop Replacement: stap 6, afbeelding 1 van 2 Broken End of a Toe Post of a Flip Flop Replacement: stap 6, afbeelding 2 van 2
    • Stick the pad to the bottom of the flip-flop right under the hole where the toe post goes through.
  7. Broken End of a Toe Post of a Flip Flop Replacement: stap 7, afbeelding 1 van 2 Broken End of a Toe Post of a Flip Flop Replacement: stap 7, afbeelding 2 van 2
    • Apply more glue to the hole and insert the strap.
  8. Broken End of a Toe Post of a Flip Flop Replacement: stap 8, afbeelding 1 van 2 Broken End of a Toe Post of a Flip Flop Replacement: stap 8, afbeelding 2 van 2
    • Let it dry for 24 hours before having a new pair of flip-flops!
Conclusie
Your flip-flops are now fixed!
Kexin Li
157 Reputatie
1 Handleiding geschreven
UC Davis, Team 1-7, Whithaus Spring 2024 Lid van UC Davis, Team 1-7, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G7
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 52
Afgelopen 30 dagen: 72
Altijd: 540
